07-07-2020 08:08 PM in
WearablesHello,
I've just got a galaxy watch active 2 and I would like the use the Samsung Ultra-Thin Wireless Charger that I'm currently using with my galaxy note 10+
When I try to charge the watch on the same pad, the light flash red and the watch does not charge (It's charging fine with its own cable from a pc USB port)
As power supplier, I'm using the original note 10+ super-fast charging attached to the Ultra-Thin Wireless Charger.
Are the pad and the watch compatible?
It might be the charger too strong?
Thank you for your help.
07-07-2020 09:19 PM in
Wearables07-07-2020 09:31 PM - last edited 07-07-2020 09:31 PM ) in
Wearables😞 Ok, thank you for the explanation
