Galaxy Watch 4 battery drain
(Topic created on: 07-02-2022 10:07 AM)
walkerx
Helping Hand
I charged my watch 4 classic lte last night and this morning less than 12hours later it is drained.
Never had this issue previously and you can't get a full breakdown of battery use.
Anyone else had similar and any ideas how to determine what has caused the battery drain.
Usually get 2 days usage out of it.
4 REPLIES 4
walkerx
Helping Hand
Fiona26
Samsung Members Star ★★
Once when I had battery drain with my active 2. A reboot seemed to help my battery drain issue. So I do a reboot at least once a week on my watch 4. Hope it's just a reboot your watch needs.
walkerx
Helping Hand
Yeh I rebooted before post and put on charge. So far it seems to be ok but annoying you can't see how quickly the drain happened
Blessed4life
Black Belt
Try clearing the cache partition, if all fails do a hard reset (factory reset)
