Galaxy watch 3 LTE not making calls
(Topic created on: 16-09-2021 12:40 PM)
Joojooz
Galaxy watch 3 LTE paired with S10
Set up mobile plan with O2, watch has separate number. Cannot make/receive calls without phone. Says 'connect using Bluetooth'. When someone tries to ring watch number, says ' person not available try later'. O2 are trying to solve it but no joy.  Help 🥺 please
10 REPLIES 10
AndrewL
@Joojooz: If you haven't done so already, please download the Galaxy Wearables app from the Google Play Store, and run through the connection process. Select your Galaxy Watch, select it again, check to see that the number code on the Wearables app matches the watch, and tap connect. From here, you will need to allow permissions for the app, and check the terms and conditions. Once you've done this, tap 'Agree', 'Agree to all' or 'Next'. Follow the on screen instructions to finish pairing the devices. Now, on the Galaxy Wearables app, go to Mobile Networks to scan for an eligible network, and follow the prompts to complete the activation. Let me know how you get on.
Joojooz
That's all been done. Esim set up, data plan enabled.
AndrewL
@Joojooz: While the watch isn't connected to your phone, can you try heading to Settings > Connections > Mobile Networks > Turn On Now. Alternatively, connect to your phone via Bluetooth, then set this to 'Auto' to see if this helps.
Joojooz
Already tried that, thanks for helping though
ynneL
Troubleshooter
I believe with O2 you need call and text on other devices turned on have you enabled it?
Joojooz
Yes that is enabled
Ambieroo
I'm on thr phone now to o2 trying to sort this had the watch since April and nothing is connecting
Joojooz
Changed a few settings with O2 yesterday, very helpful but watch still in standalone mode let me know how you get on, thanks
Joojooz
Have noticed in wearable app, remote connection, it says text, email, notifications, but not phone calls. Any help out there, thanks
