Galaxy Watch 3 - Battery Drain
(Topic created on: 11/04/21 17:39)
MrsWater
Wearables
I bought the watch mainly to use for cycling and to use Strava on it.
I cannot stop the watch using battery - for instance today it used 20% of battery on a 45 minute ride.  On longer rides it can barely last out the ride.
when using the watch to record only location services are on, no bluetooth, wifi or 3G.
Is this level of battery use normal?
7 REPLIES 7
Blessed4life
Helping Hand
Wearables
Hi I heard there's an issue with the galaxy Wear app draining the battery, the solution given is to uninstall the Wear app & that should fix the battery drain, give it a try.
JodieS
New Member
Wearables
So we have to re install the wearable app?
Blessed4life
Helping Hand
Wearables
I'd assume so, give it a try.
MrsWater
Wearables
But the app is on my phone, not the watch as far as I know so would this help the watch?
Blessed4life
Helping Hand
Wearables
Give it a try if it doesn't work then contact customer service.
MrsWater
Wearables
so are you saying to delete off the phone?
Blessed4life
Helping Hand
Wearables
Uninstall it then install it again & see if that works, search the forum for galaxy watch 3 battery drain.
