Galaxy Buds2 weird buzz sound in right earbud
(Topic created on: 24-08-2021 12:21 AM)
anao
Wearables
Hi everyone!
So I just got my fresh pair of earbuds2, but unfortunately I think sth is wrong with one othem, whenever I try listening to anything in active noise cancelling mode or in ambient sound mode I keep hearing this weird buzzing sound in the right one. I can still hear it even when no media is playing. But that sound is magically gone when I switch off any noise controls. I have no idea if that's a normal thing or some kinda bug.... and it would be a total loss if I couldn't even use them fully with all of their features.
I've tried resetting and unpairing my buds but none of it worked. Can anyone please tell me is there sth else I could do? Or should I try return them? Thanks in advance!
7 REPLIES 7
Wearables
Firstly, I would remove the bee from your ear.. if there is no bee, I would return the buds immediately for a replacement set. I've the Earbuds Pro set and the noise cancelling is absolutely amazing!!
anao
Wearables
I think with a bee in my ear I would be in no shape registering any problems 🤣🤣🤣  maybe more accurate description for that sound is when your radio loses connection but not as aggressive 😉 so you think the only option is to return it to the retailer?
Wearables
Absolutely....
Wearables
Unless you have got them wet, then stick the affected one in a cup of rice for a couple of hours/overnight to see if it dries it out...
anao
Wearables
They freshly new, the buzzing noise was there from the moment I took them out of a box, and unless they got into water  during production process I don't think that's the case... srsly no one else has the same problem?
Shelley123
Voyager
Wearables
That doesn't sound right to me, I would return them,
AB28
Wearables
hi i have thie weird problem with my buds 2 aswell for the left bud and the first time i resetted the buds it was fixed but then after a while it was back again and the sound of my left bud was at 10 percent volume while the other right one was normal at 100 percent sound have you found a solution without sending it back?
