Galaxy Buds right side volume super low
(Topic created on: 18-07-2019 08:44 PM)
Oathless
My Galaxy buds right side almost doesn't work
MODEL NUMBER: SM-R170
SERIAL NUMBER: not readable
2 REPLIES 2
AndrewL
@Oathless: Do you have the Galaxy Buds connected to a mobile device via the Wearables app? if so, open the app, select your Buds and tap on 'Touchpad > Tap and Hold > Volume Up/Down'. With this active, are you able to raise the volume of your right bud to a suitable level?
idot
Hi @AndrewL, that doesn't work for me, when I try to do that on the app it just changes the volume on my phone just like I can with the button on the side.
