Go to solution Solved
Galaxy buds right earbud battery issue
(Topic created on: 15/02/20 17:41)
EscanorPride
Wearables
Hi all,
I have an annoying issue with my right earbud. It drains much more faster than the left one.
eg. starting from 100% of battery on both buds, after one hour of use, left earbud 95%, right earbud 70%.
I read that other people complain about this, but what I didn't read is how to solve.
If can help: I tried buds reset. I don't use touchpad or notifications. Software is set to the last update.
Can anyone help?
Thanks
AndrewL
Wearables
@EscanorPride: If you don't have any commands assigned to the right Bud, and resetting them hasn't helped, then I recommend visiting a Support Centre where an engineer can inspect the Buds for you. To find your nearest one please check the link below, select 'Mobile Device > Phones, Tablets and Wearables' and enter your post code. Apologies for any inconvenience this may cause you.
http://www.samsung.com/uk/support/servicelocation/
5 REPLIES 5
AndrewL
Wearables
EscanorPride: If you place the Buds in the charging case, are they both charging to 100%? If you check the Galaxy Wearables app following a full charge, do both Buds have full battery indicators next to them?
EscanorPride
Wearables
Hi Andrew,
yes, after a full charge they are both at 100%.
AndrewL
Wearables
EscanorPride
Wearables
@AndrewL: thank you
Brauer11
Wearables
My right bud isn't working. I've tried re-pairing and resetting. Nothing has worked.
A Samsung Centre is not in my area. What can I do?
