21-09-2021 10:47 AM - last edited 21-09-2021 10:48 AM ) in
WearablesHi,
Can anyone give any advice on this please?
I often use in-ear headphones without issue, but when I use my Galaxy buds Pro, they cause severe discomfort.
I've just googled the issue to find a solution and seems it's a known / common problem with no real solution.....
What can I do?
Thank you
#galaxybudspro #Earinfection
21-09-2021 11:37 AM in
Wearables21-09-2021 04:56 PM in
WearablesHi @s1lang Some customers like @Blind_Marv found better comfort by purchasing Memory phone Tips . I have not used them myself(though have Buds2 rather than pro) but these ones certainly seem compatible. https://www.amazon.co.uk/SOULWIT-Replacement-Compatible-Isolation-Portable-Black/dp
A previous thread on the issue,though some of the companies mentioned here do have the Memort Foam Tips designed for the Pro. https://eu.community.samsung.com/t5/wearables/foam-tips-for-galaxy-buds-pro/td-p/2830094
One Ui 5.0,Android 13 .
22-09-2021 04:11 PM in
WearablesThank you
Tbh - given the cost of the headphones and the issues they've caused, I'm just going to try and return for a refund 😞
Got some similar Anker ones instead that are working perfectly out the box
