08-11-2020 07:33 AM
Hello,
I have got the Galaxy Buds Live and I am experiencing a behavior which I am not sure it is normal.
When I listen to the music, the buds deliver a good amount of bass but once I rise the volume over around 70% (I am using a Galaxy S10 Plus) the Bass drops and it remains like that even lowering the volume. Only going down to 0 and up again it restores.
Enabling/Disabling noise reduction feature does not have any effect on this issue.
Sometimes this does not happen as soon as I rise the volume but only after some beat. It looks like a battery protection issue, like if the battery could not provide the needed amount of current to the chip while the drivers could handle it without distorting.
Do I have a defective unit? Or it is normal?
Thank You in advance
Best Regards,
Antonio
19-01-2022 04:52 AM
SAMEE!!!! I have the exact same problem and I am surprised that nobody else reported it. It's so weird like I don't listen to music above 70 percent anyways but when you are pumped up you just turn it up, then you realize that the bass is gone! It's just really disappointing. I hope you fix this.
Tell us if this is normal or not
Thanks!
12-02-2022 01:58 PM
I’m having a similar issue. Haven’t been able to find a solution. I was happy with the buds, worked fine for about a year and now the sound sucks. There’s random popping in the left bud and the quality keeps fluctuating. Goes from muffled to tinny to close to normal at what seems to be random. So annoying. Wtf Samsung?!
