Galaxy buds case led stays on
(Topic created on: 26/12/19 11:55)
Titiriti
Wearables
Basically , the led on the outiside is always green never turns off. When I opet the case the inside light doesnt turn on. The buds are at 95% battery, wont charge past that. Has anyone encountered and solved this issue? Thanks!
5 REPLIES 5
CarloL
Wearables
Hey @Titiriti! I would recommend visiting your closest Samsung Support Centre so that an engineer can have a look at this for you: https://www.samsung.com/uk/support/service-centre/
Tim999
Wearables
Mine has just started doing the same thing - did you ever get a resolution?
Anonymous User
Not applicable
Wearables
Mine is doing the same. Did you find any solution other than going to a repair center?
davaslayer
Wearables
mine too happened after  an update about 6 weeks ago
ubergeekinc
Wearables
Can we bump this and get a fix action besides take them to a repair center?
