Go to solution Solved
Galaxy active 2 - Sudden battery drain?
(Topic created on: 06-10-2021 08:01 PM)
Niknak31
My watch has been fine and I've had it for about 6 months but yesterday whilst at work it suddenly went into power saving mode as it was down to 10% battery even though it was 100% that morning.
Today it did the same. Why would my battery suddenly drain and I've not changed any settings either.
Fiona26
Samsung Members Star ★★
Try rebooting the watch, see if it helps.
3 REPLIES 3
Fiona26
Niknak31
OK I shall give that a go thanks
Niknak31
Hi, I just want to say thank you for your advice - it worked!!! For the last 2 days I have worked a full day and it's still on 82% so thank you.
