Fit2 pro very hot
(Topic created on: 29-01-2020 12:04 PM)
AnnaM3
Yesterday my fit 2 pro got very hot in the charger, I took it out. I can't turn it on, the screen is black. I never had any problems wit fit2 pro before. Is it broken?
1 REPLY 1
AndrewL
@AnnaM3: If you press and hold the power button for around 7 seconds, does the device power on at all? If it is completely unresponsive after being on charge, then I recommend visiting a Samsung Support Centre where an engineer can inspect the device for you. To find your nearest one please check the link below, select 'Mobile Device > Phones, Tablets and Wearables' and enter your post code.
http://www.samsung.com/uk/support/servicelocation/
