24-06-2022 05:07 PM - last edited 24-06-2022 05:11 PM ) in
Wearables24-06-2022 05:20 PM in
WearablesHi @Adam1998 ,
May I ask if this only happens when you shake your head?
If not, please check for software updates on your earbuds and connected device. Make sure your earbuds and phone or tablet have the latest software version installed. If an issue occurs when using a certain app, such as Spotify, make sure the app is also up to date.
24-06-2022 05:25 PM - last edited 24-06-2022 05:25 PM ) in
Wearables24-06-2022 05:48 PM in
WearablesNo worries! Can you please define what you mean by weird? Do this affect all the sounds and apps? When you shake your head does the Buds location move considerably from the phone or device that you have these connected to?
24-06-2022 06:11 PM in
Wearables24-06-2022 06:27 PM in
WearablesIf this only happens when you shake your head, it may indicate that the communication between the devices will be poor or obstructed. Try the following:
24-06-2022 06:34 PM in
Wearables25-06-2022 11:05 AM in
Wearables25-06-2022 11:14 AM in
Wearables25-06-2022 06:15 PM in
Wearables
