Go to solution Solved
Dex station and Gear VR compatible cases
(Topic created on: 23-12-2017 12:12 PM)
blazefalconburg
Are there any cases available for the Note 8 that are compatible with the DEX and the Gear VR? It seems like a massive oversight to not make these compatible with cases. The fact that the DEX station need a USB connector instead of being wirelessly connected is backwards at best, but to also have to remove your case to plug it in is ridiculous.
BandOfBrothers
Samsung Members Star ★★
Hi @blazefalconburg
There's some suggestions in this thread xda-developers.galaxy-note-8/accessories/case-allows-to-dock-dex.
When looking at certain cases to choose from check out their compatibility and reviews. There maybe an option to contact the Manufacturer directly.
From what ive read some of the oem original Samsung cases are compatible.
Daily Driver > Samsung Galaxy s²⁴ Ultra 512Gb ~ Titanium Black.
I'm here to help. " This is the way. "
1 REPLY 1
BandOfBrothers
Hi @blazefalconburg
