Defective Samsung Earbuds Pro?
(Topic created on: 12-02-2021 05:10 PM)
Fobss
Pioneer
Hi guys, as you know the new earbuds Pro have ANC however I'm going to be totally honest when u turn on the future it makes basically 0 difference to what I can hear. I'm wondering if my earbuds are faulty or if the ANC is literally that weak to a point where I could have TV volume at 5 and still be able to hear it as if ANC was off?
The ambient noise feature works great however the ANC is horrible if I rub my fingers against each other even that is audible to a level that it would be if ANC was off any response is appreciated thanks!
3 REPLIES 3
efx
Pathfinder
I've just posted the same issue.
Gilani
Pioneer
It's not defective it's just a poor quality ANC in these buds
-Robot-
Samsung Members Star ★
I haven't notice this, I think they pretty good considering. They aren't my bose wired noise cancelling but ok
If you buds are faulty I would Co tact promotion before 30 days are up or they will only repair as opposed to replace them. Repair take 2 week I believe
