The other way I have found works is to make sure the sensor on the watch is clean, then turn the watch around on your wrist so the sensor is against your palm side of your wrist make sure the watch is tight and then make sure your fingers touching the buttons are damp. It's a lot of messing but I found this worked. Hope that helps
