budz live problem?
(Topic created on: 24-02-2021 11:59 AM)
Kerryann23
1 bud keeps disconnecting, yet the sound to pause still works.
Ive done the recent updates but still having problems with cracking sounds too
8 REPLIES 8
WelshPaul
Troubleshooter
Return them for repair or replacement.
My advice comes from being a UK Samsung iPhone user.
Current Devices:
  • iPhone 14 Pro 256GB Deep Purple
  • Samsung Galaxy Buds+ > Model: SM-R175.
Kerryann23
they have to repair them as they won't replace
WelshPaul
Troubleshooter
Frustrating I bet!
Good Luck
Current Devices:
AndrewL
@Kerryann23: Can you try placing your Galaxy Buds Live back in their case for 10-15 seconds, and close the lid. Reopenthe case to enable Bluetooth pairing mode, and check your phone's screen. Alternatively, try placing the affected bud in the case by itself. Does the charging light turn red, then green to indicate that it is fully charged?
If this doesn't work, please make sure that you are within 10 metres of your phone to stay in range of the Bluetooth connection. I also recommend checking for an update on the Galaxy Wearables app by going to About Earbuds > Update Earbud Software > Download and Install, to see if this helps. You can also try resetting the Buds by opening the Wearables app on your phone > General > Reset.
Kerryann23
thanks but I've tried all this. samsung are repairing them.
Kerryann23
They never told me the process and just received an email saying collect and exchange on door.
does this mean I'm receiving a replacement set?
WelshPaul
Troubleshooter
WooHoo... Looks like you're getting them replaced after all! 🤞👍
Current Devices:
Kerryann23
Nope the Dpd guy just came with a box.
