Bouncing blue musical note won't go away!
(Topic created on: 10-05-2024 12:43 PM)
Members_ZAmII2n
I have a NEW Samsung 6 watch, and on the home screen I keep getting a bouncing blue musical note that won't disappear despite not playing any media.  I have restarted the watch but it's still there!
2 REPLIES 2
MontyS23U
Pathfinder
Tip: how to disable music note icon on the GW4 when playing music
This little note icon has been bugging me for a long time, especially since I'm not using stock music controls. But I've finally found a way to disable it:
  1. Open Settings on the watch
  2. Go to About watch -> Software
  3. Tap on the "Software version" until you see developer options enabled
  4. Go back to main settings menu. "Developer options" should appear near the bottom
  5. Open developer options
  6. Select "App notifications" (near the bottom)
  7. Select Show all
  8. Select "Wear OS"
  9. Disable "Ongoing media notification" toggle
NikkiCarter
When I go into Wear OS, I only have Show Notifications (already off), then categories of System Notifications and System Notifications-Silent that are both off?
How do I do this?
