05-08-2022 08:55 AM in
05-08-2022 09:19 AM - last edited 05-08-2022 09:20 AM
Hey! It seems like a common issue, I have it too (I charge mine when before I go to sleep and after I wake up), try to not use animated watch faces and uninstall apps you don't use. Since the Watch4 uses WearOS, it uses more resources.
05-08-2022 11:14 AM in
05-08-2022 01:47 PM in
06-08-2022 01:28 AM in
13-08-2022 10:57 AM in
Hey. To uninstall an app, go to the apps screen (swipe up on the home screen), locate the app you want to uninstall then tap and hold on it. After that, you will see an "Uninstall" button. Press that. After you pressed it, another screen will show asking you for the confirmation of uninstalling that app. After you click ok, the app will be uninstalled.
