Youtube issue on Q6FN
(Topic created on: 17/05/19 18:13)
chrisnewton
Navigator
TV
Hi I have a 55" Q6FN and I have a little issue with the you tube app.
When the TV has been off overnight and I open YouTube app it sometimes just crashes..basically I can scroll though the menus but they are all blank. The only way I can get it to work is to sign out of the app and re link my account via my phone and its then fine.
All other apps seem fine.
Anyone else had this?
22 REPLIES 22
chrisnewton
Navigator
TV
ok managed to catch the error on Video
https://youtu.be/mvYBaCcSYfA
I have tried re-setting the hub, unplugging the TV, wired, and over Wi-fi, re-installing the app..nothing works
If i sign out of the app or unplug the TV it works for a while but then happens again
Any Ideas?
ChrisM
TV
Hi @chrisnewton
That's not coming up as a UK model. Where did you buy the TV? Are you based in the UK?
chrisnewton
Navigator
TV
What do you mean it's not coming up as a UK model? I bought it from richer sounds and yes I am in the UK.
Model number is QE55Q6FNATXXU
TracyR
TV
If all other apps are working fine, it would suggest an issue with YouTube itself, I'd recommend reaching out to the app developer directly to make sure there are no issues on their end.
:smiling-face:
Say "hello!" and
Introduce Yourself, or virtually hangout in the Samsung Lounge
paul1277
Black Belt
TV
:smiling-face:
First they say it is not a uk model which it is and now they blame the YouTube app. Rubbish,  if that was the case every owner would have the same issues. It sounds to me like a faulty tv. Report to you retailers as a faulty tv, because it should work as advertised, if it does not it is faulty.
Paul
Leet2274
TV
Hi chris
Yes, thats same as my q9fn started doing after latest update, couple of seconds would be acceptable for videos to load up
Yesterday i filmed mine just like you have there for 5mins and nothing... got fed up and turned video off after 5 mins, but then did another 2min one where i kept closing the app down then going to home menu and opening youtube again to show that that didnt work..
I unplugged the tv eventually, still does it pretty much every time you open youtube app up, always get theose greyed out boxes for varying amounts of time before videos fully load to be able to select and play them
m4dm4n
TV
Same thing with Q7FN, in the last 2 weeks. Youtube works ok for some time, and after if get stuck, I remove and add account. It works for some time again until it gets stuck again.
pali2704
TV
The same thing happend to my Q6FN after the last firmware update. It used to be fine. Now I have to reinstall youtube everytime I try to use it.
chrisnewton
Navigator
TV
any chance someone from Samsung can help us out here?
