Go to solution Solved
wiring connection
(Topic created on: 21-03-2023 10:46 AM)
alfred81
Can you please advise the correct wiring connection between my recently purchased TV 55"s95b OLED 4K and a stand alone Phillips Video Player DVP 3120   photo attached.
Thanking you in anticipation.
kind regards
Alf Wilkinson
2 Solutions
Robin999
Legend
RCA to USB is doable. Leads available on Amazon. Haven't found a SCART to USB though.
Robin999
Legend
If that empty HDMI socket is going spare then utilise that with a SCART to HDMI converter. Comes with all leads inc USB lead to plug into the 5v USB socket on TV. Available on Amazon
Scart to HDMI Cable Converter with Scart and HDMI Cables, Male Scart In HDMI Out Converter, Scart HDMI Video Audio Adapter for Sky/ DVD/ STB with Scart output to Display on HDTVs https://amzn.eu/d/iC0utOU
12 REPLIES 12
Ginga_p
Hotshot
You couldn't use a a scart to hdmi cable. Or rca to hdmi cable
G G
nowdeleted
Big Cheese
Does your TV have a scart socket ?? or like suggested scart to hdmi
alfred81
yes, but can I connect the rca to the usb sockets and is so which one.
thank you in anticipation
regards
alf
alfred81
Unfortunately no scart but plenty of usb
connection
thank you
Ginga_p
Hotshot
The video player in the photo has a scart connecter.
G G
Robin999
Legend
alfred81
There are no scart  connections on the  TV
alfred81
Ginga_p
Hotshot
Use a rca to usb look for baolongking on amazon or do seach on google the photos are quite self explanatory.
G G
