Which TV to buy. Help!
(Topic created on: 26/03/21 07:47)
ficehubo
TV
Hi all,
I’m moving into a new house in the next few months. Really undecided on which tv to get. Narrowed down to QLED as worried about burn in etc with oled. There’s some amazing deals on at the minute for Samsung’s. I can also get a perks at work discount at Samsung. I was sure I was going to get a 65 inch Q95T.
My budget was £2000. Now I’ve seen great deals for Q950R (75 inch) and Q950TS (65 inch). What’s your thoughts on which one to get, wanted to get in quick incase sells out. I’m still happy to get the Q95T just read on some forums the 2019 models are better than the 2020.
thanks for your help
2 REPLIES 2
JAMES4578
Superuser I
Superuser I
TV
Hi @ficehubo  You may wish to consider  the Q95N Neo QLED ,  the incorporation of  quantum dot technology delivers saturated and nuanced colours, and with the benefit Filmmaker mode  the images are considered to  be extremely accurate.  Sound is also impressive thanks to  Object Tracking Sound.  https://news.samsung.com/global/breaking-down-the-early-media-reactions-to-samsungs-2021-neo-qled-li...    https://www.samsung.com/uk/tvs/qled-tv/sound/  https://www.techradar.com/uk/news/best-samsung-tv      This Tv just a little over your budget at £2199.    However the Q95T would be fine and other alternatives here https://www.trustedreviews.com/best/best-samsung-tv-3980889
Video of 2021 lineup:
SF
TV
2021 models are as good as 2019 models. But the 2020 models are a step back even prior to 2019
