Wall connector
(Topic created on: 22-11-2023 06:30 AM)
Alibob73
I have a 40” UE40D5003BW that is still going strong even though it’s 12 years old! I want  to mount it on the wall, do I need special connectors or does it just  screw on the bracket? I can’t find any information about this in the manual, thanks
2 REPLIES 2
ChrisM
SuperStar
Hi @Alibob73!
When you mention 'screw on the bracket', do you have a compatible wall mount for your TV?
JAMES4578
Samsung Members Star ★★
@Alibob73 You can find all the information you need here, as suggested , as advised a compatible wall mount is strongly advised.  https://www.samsung.com/uk/support/tv-audio-video/how-to-mount-a-samsung-tv/
Your model has lasted well though may run into problems at some point.
