Vertical Lines on TV
(Topic created on: 02-06-2021 07:47 PM)
Smcroy
Hi there. I have a Samsung 65in curved TV and just recently it’s displaying 2 vertical lines up the middle.
any ideas on the fix for this, can’t it be fixed ?
or do I need a new one
4 REPLIES 4
Aklima
Big Cheese
Hi,
Only way is to have the screen replaced. If u have warranty then u can get a new one if not then u can buy a new one.
Smcroy
Hey thanks. I imagine cheapest way Is to buy a new tv though?
Aklima
Big Cheese
Yes it is
JAMES4578
Samsung Members Star ★★
Hi @Smcroy  You could try disconnecting cables and switch Tv off at wall for around  5 minutes and try again.  Does factory reset make no difference. ?  I a s fault found when  doing picture Test, support-self Diagnosis-Picture Test.   If so then a fault ,though it could  be  the power board and options are repair or new TV.  If you have had TV  for some time a new model may well be the better option.
