using smart remote on virgin media
(Topic created on: 23-09-2018 08:26 AM)
paul65
I want to use my smart remote to access "my shows" - my previous recordings from my virgin media tivo box.
This may be simple but I cant work out how to do it!
3 REPLIES 3
AndrewL
Hi @paul65
If you have calibrated your Smart Remote with your Virgin Tivo box then you should be able to cycle through any on screen menus using the 'wheel' in the centre of the remote and select your chosen option with the button in the middle of the wheel.
Infistyle
Hello. I'm sorry but do you know how to calibrate Samsung remote with virgin TiVo box.?
thankyou Steve
Jolin123456789
Doesn’t work all smart buttons lead to guide you can’t get into the menu screens from there. How do I get access to the virgin menu structure using smart remote?
