urgent help
(Topic created on: 23/02/21 06:59)
alison22
TV
I'm so sorry tp bother you all, especially with the current situation. but I'm desperate. thr power on, and rrwind and forward buttons on my samsung remote aks9-00084v suddenly stopped working, all others work fine
. I've tried changing tge batteries to brand new ones, didn't work. tried otyers too still didn't work. I'm seriously ill and predominantly bedridden including paralysis yet without the care I desperately need amd i know it soubds silly but having the tv on in the background is thr only thibg that helps me get through the day. i can't even afford tp buy a new remote eirher. does anyone know a fix?? please help asap. mant thanks indeed. my love and prayers to you all dear souls. alison. God bless x x alisonlouisebell@yahoo.co.uk  
3 REPLIES 3
PaulMrT
Overseer
TV
You'll need a new remote BUT don't need to buy Samsung branded. I had issue with one of my Samsung TV's remotes and found a generic version exactly same bar no Samsung branding for 5UKP approx via Amazon so I'd suggest search on there.
antikythera
Overseer
TV
In addition to what Paul said you shouldn't give your email address out on public posts. I strongly advise you to edit your post and remove it
PaulMrT
Overseer
TV
I didn't even see that just the bit about remote issues then replied..
Good advice though 👌
