Upgrade One connect box for UA55F9000
(Topic created on: 15-09-2019 02:02 PM)
Muhammadshah
Hello,
I have UA55F9000 and the One-Coonect Box is damaged. I want to purchase a new box that should be compatible with my TV.
Could you please suggest the one-connect-box I can attach to UA55F9000.
the old one is SEK2500
thanks,
10 REPLIES 10
EL ALAMI HAMZA
Mastermind
Hi @Muhammadshah
the sek2500 it is out of stock the same for the sek3500
I advise you to take the last case
the sek4500
Muhammadshah
Hi
Is there any compatibilty for SEK4500 for UA55F9000.
thanks
EL ALAMI HAMZA
Mastermind
yes absolutely it is compatible with the sek4500
Muhammadshah
Hello Elalami,
I purchased the SEK4500 from Amazon. Unfortunately the cable from the Display "UA55F9000" is bigger and cann't be inserted in to SEK4500.
The solution didn't worked for me. seems I have lost my money to purchase SEK45000.
What to do with this SEK4500 is useless for me now?
Regards,
EL ALAMI HAMZA
Mastermind
Muhammadshah
Hello Elalami,
There is no HDMI interface in UA55F9000, and the snap you have mentioned for the connectivity,
EL ALAMI HAMZA
Mastermind
the cable provided case sek4500 must be connected to the old case of the tele on the socket hdmi
Jasonchapman
Send it back
upperventures197
Hello please I need help. My one connect box, for tv model: UA55F9000AR, is not working. I have seen the conversation above and don't know if it eventually worked.
