04-08-2021 02:49 PM - last edited 05-08-2021 09:14 AM ) in
TVhello, my tv doesn't find a update and I have only a phone now no usb stick, downloaded the update, got my phone to show up, all other files are showing but not this, not inside another folder and it is unzipped. tv is sharing network from my phone so don't know why it can't find the update. do I need to get a usb stick to get it updated
06-08-2021 02:59 PM in
TVHi @zilla908 The only update options are over the air on Tv or by downloading firmware to USB and updating that way. see more here https://www.samsung.com/uk/support/tv-audio-video/how-do-i-update-the-software-on-my-samsung-smart-t...
One Ui 5.0,Android 13 .
11-08-2021 09:26 PM in
TVcan I get a fix to the thing that I can't update the firmware. looked at threads at us community and there's the same problem with people. I bought a usb stick, which doesn't really differ from the phone storage but the tv does not recognize the firmware update file. so could the update file be in any different format. if they could do anything about this at samsung
15-08-2021 04:04 PM in
TVwhy can' t I upgrade it with a usb stick. formatted as fat 32 i pretty sure. it can read it but file is not showing up there. and if your thinking of some of the usual problems it's none of those
15-08-2021 04:05 PM in
TVI'll contact samsung if I can get a answer there
