06-10-2020 11:49 PM
Just got this tv. Went into advanced setting, sound equiliser to up the bass and generally personalise, but moving the sliders from bass to treble does nothing. There is no difference in bass sound, in fact I turned all the eq up and it didn't change a thing!
07-10-2020 02:53 PM
Hi @gentv
Have you tried resetting the sound on your TV? Go to Home > Settings > Sound > Expert Settings > Reset Sound. Then try adjusting the Equaliser.
07-10-2020 03:25 PM
Yep, no different.
09-05-2021 06:26 AM
Same here in our new 2021 model. Absolutely horrendous sound with zero base. Last Sammy I’m buying!!!
