Go to solution Solved
UE55MU7000t one connect box connection problem
(Topic created on: 22-11-2020 01:35 PM)
Abram102
TV
Hi so I bought a second hand Samsung tv UE55MU7000txxu and doesn’t see one connect box...
my remote allows me to on and off tv ...that’s all;(
please help
need at least OCB model number compatible with my tv model
thanks...
PaulyWauly36
Navigator
TV
make sure the connections are firmly in,if still probs buy new cable, ebay etc
1 REPLY 1
PaulyWauly36
Navigator
TV
