26-12-2017 06:40 PM
My now out of warranty UE55ES8000 is randomly restarting or turning on from standby. I have tried all suggestions from a factory reset (from the engineers menu), running the software update ad infinitude to unplugging for “x” minutes. Nothing works. It has been doing this for a few months now.
Before I throw this very expensive tv in the bin and go buy an LG my wife suggested I post for help *****.
At present it won’t even load the Smart Hub (says its updating, then finishes, them fails to load, then says it is updating, then finishes, then fails to load, etc.).
Has anyone else seen this, or have any new ideas please?
Thanks.
2 weeks ago
yes I am having the same problem too
2 weeks ago
Hi. I seem to have solved this problem. I believe I updated the firmware and the problem went away. I still have the TV though it now has a picture problem, lots of vertical banding.
