18-03-2020 12:56 PM
I wonder if anyone can help with this. I have a UE55D8000 which isn't letting me change the region.
We've had it from new (from a reputable supplier) and always used it with a cable box, so never needed to set-up with a normal tv aerial.
However, I now need to tune it using a feed from a roof top aerial, but when I do the channels are all screwed up - lots of UK ones missing and all odd numbering. I've tried to change the region, but it's stuck on 'Netherlands' and when I try to select 'other' there are no other options.
The main support desk is shut at the moment, so I'm hoping someone here can halp.
Thanks
