UE49MU6500U not finding hdmi device
(Topic created on: 30-06-2018 09:07 AM)
Edgie70
Troubleshooter
Hi all , I had to disconnect the TV last night and unplugged all the hdmi cables , now it won't find the Amazon box when it searches for devices even tho the Amazon box is turned on , I know the TV memories the hdmi input device but it's now not finding it , is there anyway to reset the hdmi input so it forgets the devices ??
3 REPLIES 3
ChrisM
SuperStar
Hi @Edgie70.
Are you able to try plugging into a different HDMI port to see if that makes any difference?
paul1277
Black Belt
@ChrisM wrote:
Hi @Edgie70.
It should just work.  I find things like this mean a faulty set and if its within the first 28 days have it replaced.
Edgie70
Troubleshooter
Hi Chris , when I originally set it up the TV found the device but I had to disconnect it all and now it won't find the device when it scans , I had to add it manually , it works fine but couldn't understand why it wouldn't find it when scanning
