UE49KU6470 Smart 4k Ultra HD Black shadow in centre screen
(Topic created on: 19-03-2020 09:55 PM)
SteveHPage
Hi
I hope you can help!?
I have a black shadow effect just left it Centre from top to bottom of the screen. Any guidance?
3 REPLIES 3
AndrewL
@SteveHPage: If you go to Settings > Support > Self Disgnosis > Picture Test, and follow the on screen instructions, does the issue persist? If so, please contact a Samsung Support Centre to arrange an engineers inspection. To find your nearest one please check the following link, select 'TV & AV > Television' and enter your post code: http://www.samsung.com/uk/support/servicelocation/
I you have recently self isolated due to Covid-19 then you will be required to wait until the suggested 14 day period has elapsed to make your appointment.
Lbennett20
Did you solve the issue? Mine also has that
Christine1962
Mine is also the same did they fix it
