UE46ES6100 flickering
(Topic created on: 28-02-2023 12:16 PM)
Renginys
TV
The TV works fine for a couple of minutes and then it start flickering (attaching a video).
Maybe you know which part is broken
1 REPLY 1
JAMES4578
Samsung Members Star ★
TV
Hi @Renginys check you have the latest firmware on the Samsung support site,if not can be downloaded to USB.  However latest update is 2010.0  from 2020.  https://www.samsung.com/uk/support/model/UE46ES6100WXTK/ Try  the following settings,  Home -Settings > General- Power and Energy Saving, advisable to disable Brightness Optimisation, Brightness Reduction and Motion Lighting.   applicable.  If all fine or still issue  there .  Can you check all cables and connections to ensure everything is secure. If so press and hold in Power Button for 5 seconds or so to reboot until you see the Samsung logo. If does not solve the issue unplug at mains for around 5 minutes, you could also try a Factory Reset. If still flicker  after  troubleshooting do a Picture Test, Settings-support_ Self Diagnosis- Picture Test.
If tests fail you would need to get in touch with Samsung Support for Advice,however this a 2012  model and repair options may well be limited.  Generally Tv's  will encounter issues at this stage.
One Ui 5.0,Android 13 .
