Ue43nu7400 panel type
(Topic created on: 20-02-2022 02:12 PM)
Edgie70
Troubleshooter
Hi all , couple of a technical questions , does anyone know the panel type of the ue43nu7400 whether it's a VA or an IPS ??? Also is there any way of finding out the nits brightness of it ??
Thanks
3 REPLIES 3
JAMES4578
Samsung Members Star ★★
Hi @Edgie70 Seems can be either VA or IPS on the 43 inch according to Display Specificationsl and posts on Av Forums. Though Nu7100 all listed as VAhttps://www.rtings.com/tv/learn/ips-led-vs-va-lcd https://www.avforums.com/threads/samsung-nu7400-series-any-reviews.2171893/page-28 DS does not have a peak brightness for the 43 inch model but lists the 50 inch at 200 nits ,though a poster on Av rekons it is 300. https://www.displayspecifications.com/en/comparison/21f869e77
Edgie70
Troubleshooter
Thanks James , I'm looking at getting another TV , not a massive amount of money but would you recommend a VA or IPS panel ? Thanks
JAMES4578
@Edgie Think in the price range you are looking for would go for VA panel. Will offer better contrast ratio and generally better for movies for instance. Though will not have the widest viewing angle.
Can see some information here https://www.electronicshub.org/va-vs-ips/
