UE43JU6000 screen horizontal lines fault
(Topic created on: 25-03-2019 04:50 PM)
MikeyRobsYa
Hey,
I'm looking for some help please.
My Samsung is only just over 2 years old and out of warranty. It has developed horizontal lines on the bottom of the screen and kind of displaying a double image in the lines of the above lines image.
Anyone have an idea of a fix ? Or just take it to a store.
Thank you
4 REPLIES 4
ChrisM
SuperStar
Hi @MikeyRobsYa
Are you still having this issue? Has there been any physical damage to the TV screen?
MikeyRobsYa
Hi mate.
Yes the problem Is still there. And no damage to the TV, it just happened 1 day, the screen went wonky. Have you an idea with my issue ?
MikeyRobsYa
This is the issue at the bottom of the screen
mathes_dsgm
My UE40D6100 has the same issue, in my case the horizontal band is an the top and it only happens with my PS4 or PC when I choose 59HZ on HDMI, it does not happen with my PC at 60HZ. I think the T-COM might be faulty
