UE40KU6450S problem with bluetooth headphones.
(Topic created on: 04-01-2018 07:49 PM)
s21fot
Hi,
I have a UE40KU6450 TV. I've recently bought bluetooth headphones to use it. No problems with pairing. The problem is that sound in headphones is interrupted from time to time by something. What I found is that there are no interuptions when I remove batteries from TV remote controller.  It looks like remote disturbs bluetooth signal between TV and headphones.
Can you advice some solution for that?
I know that each time I can remove batteries from my remote control, but this is not the right solution.
Best regards, K
1 REPLY 1
Koniuszko
Have the same problem with Samsung UE48JS8500 and JBL bluetooth headphones. Thanks for the tip with batteries :smiling-face:
