Go to solution Solved
UE40J5000AK no surround through Optical Cable
(Topic created on: 09-09-2021 02:30 PM)
Nevarnost
TV
Hello everyone, i just bought a 5.1 surround sound system, and connected it to my tv with an Optical Cable but the TV outputs only stereo sound. What can i do? I already set the TV to output to "external speakers" and set the digital audio to "PCM" but still i can't get 5.1 surround.
(FYI the surround system is a Sony HT-S20R
#UE40J5000AK
Go to solution
41 REPLIES 41
Nevarnost
TV
Ok so, my TV is the UE40J5000AK which has only 2 HDMI ports. One is unlabeled and the other is STB, so no ARC audio.
My 5.1 system is a Sony HT-S20R, which has Optical and HDMI ARC output.
How should i do my connection to have true 5.1 and not a stereo mixed between the speakers?
AntonioSoares
Voyager
TV
Let me check both manuals. To give you the correct settings.
Any set-top box for TV?
For now let's focus on PS5 + TV + Receiver.
No need to have ARC.
I'll get back as soon as possible, if no-one else joins the thread.
Cheers
Nevarnost
TV
Thank you very much for your kindness!
No, i don't have connected any set top box or external devices other than these three
AntonioSoares
Voyager
TV
By the way, I'm just a fellow member of the community with no attachments to Samsung! 😁
AntonioSoares
Voyager
TV
Hi,
could you please post screenshots of the audio menu on the TV so I may check the available options?
I'm looking in the manual but lacks those needed parts...
ENG-NLDVBEU1J-1012-1113.pdf (samsung.com)
What is the firmware version of the TV?
You may see there's an update available.
UE40J5000AK | Samsung Support IE
Nevarnost
TV
  Hello, these are all my audio options available. Dolby and DTS are grayed out unfortunately
AntonioSoares
Voyager
TV
Ok.
with this soundbar (sorry I was focused on you using a receiver), you can only use Optical for 5.1 and Dolby D.
I'm checking the rest....
AntonioSoares
Voyager
TV
Thanks!!!
Let me check my TV audio settings as they are similar, although a newer model.
AntonioSoares
Voyager
TV
Ok.
Dolby Digital is only showing up available on HDMI 2, in my case.
I have a set-top box on HDM1 and it happens like in your case.
So...
  1. Connect PS5 to HDMI2
  2. Configure PS5 to Dolby D Bitstream
  3. Go to Audio menu on the TV and check if Dolby D is not grayed out and select it.
  4. Select speaker output to External/Optical
  5. Tell me if it worked 😁
AntonioSoares
Voyager
TV
One more thing...
follow these instructions on IGN for PS5
How to Enable Surround Sound - PlayStation 5 Wiki Guide - IGN
This is an excerpt with important info:
"If your PS5 is connected to your TV, with your TV sending audio to the speakers over Optical or HDMI ARC, you may need to select Dolby or DTS here in order for surround to work, since other connections may not have the bandwidth for uncompressed LPCM in more than two channels."
