UE40H6290ASXTK Default Front Color Setting
(Topic created on: 10-02-2020 03:26 PM)
Dessan
Hi, I have a UE40H6290ASXTK model Samsung Smart TV and I accidentally changed my front color setting from service menu and need to know the default front color setting. Thank you.
5 REPLIES 5
ChrisM
SuperStar
Hi @Dessan
If the change was made using the engineer's menu on the TV, we'd suggest contacting our Audio-Visual specialists to have this changed back. You can contact the team on 0333 000 0333 between 8am - 10pm, 7 days a week.
Hope this helps!
Dessan
Thank you for the quick reply Chris. It has changed from Option>MRT Option menu. If I reset my TV to factory settings from service menu, will the problem be solved?
CarloL
Hotshot
A Factory Reset of the TV may help restoring the colour to the default settings. Should this not help though, then the AudioVisual team would be the next step.
Dessan
I finally reset my TV to the factory settings and my front color is U-S-V 63 right now. Colors aren't changed as far as i see but guys just want to know, what exactly front color affect on a Samsung TV? This information can also help others. Thank you again.
masterx1
what is the front color option doing? I just changed it and see no difference or effect between many of them
