Had this tv for a month now and noticed the bezel has warped!..anyone else had this problem?..called samsung they are sending out an engineer on Monday ñot sure what they can do with this!
Hi
Is the bezel plastic? If yes then it must be getting hot from the LEDs and is essentially melting, does it get hot to the touch? If it's metal its hard to see how that could bend like that, and if metal I would suggest maybe it was always like that and now you've just noticed.
Let us know what the engineer says.
Regards
Phil
Hello Phil
In answer to you're question it's a metal bezel. I would have noticed if it had been like that from the start..will let you know what the engineer decides..not sure what they will do could just be a replacement bezel? We shall see
Paul.
