29-01-2024 04:26 PM
I have a Samsung UE50MU6120K TV, which was working fine until about an hour ago. Then, when I turned it back on, the volume keeps automatically going all the way down and the red “standby” light on the bottom of the TV keeps flickering (as if it’s receiving a constant signal from the remote). It’ll accept commands from the remote, including me trying to put the volume back up. But, then it just brings it back down again. My 5.1 sound system display I have connected also says “Volume Min”, as if it’s having the volume turned right the way down.
I’ve checked all the batteries in all my device remotes, reset the TV to factory settings, disconnected and reconnected all the cables. Nothing seems to be resolving it.
Solved! Go to Solution.
31-01-2024 02:18 PM
I don’t know if it’s the same for you but, I discovered that it was some sort of glitch with my Apple TV 4K remote, like it was constantly sending a “Decrease volume” signal. I’d seen several other people had said it was the same problem and so I reset the remote. This instantly sorted the problem!
31-01-2024 12:20 AM
Ok, this is happening here too, exactly as you described it. I thought that I caused this when I added an HomePod to the setup, but the led is constantly blinking even if the HomePod is completely offline.
It has to be a software issue at this point.
31-01-2024 02:18 PM
31-01-2024 02:37 PM
Ok, thanks for the tip, I’ll see how to reset it and I’ll update the thread tonight!
01-02-2024 10:57 PM
This has fixed the issue on my end too. Thanks a lot for this, it was driving me crazy.
08-10-2024 08:51 PM
The volume issue happened the same for me when my apple tv 4k updated today. Resetting the apple tv remote fixed the issue. Thanks for the fix!
10-03-2025 04:25 PM
Hi. I have the same problem. How do you reset your TV remote. Looks like that is what u did to solve the problem
10-03-2025 04:31 PM
You have to hold the TV/Control Centre button and Volume Down button for 5 seconds. Then you should be able to use it normally after. Here’s the Apple support article:
10-03-2025 04:49 PM
I'm trying but nothing happens. When my TV goes down to volume 0. Then my remote does not respond to TV. I had to press buttons on the TV.... Volume up... then it comes doen again. I have a Samsung TV. This makes me crazy 😂
10-03-2025 04:55 PM
Oh, sorry. I don’t know what else to suggest then. I’ve tried Googling it quickly, but people have either recommended you keep doing the same thing I tried or recharging your remote for a few hours.
