TV screen goes black
(Topic created on: 22-11-2021 10:38 PM)
Smc14
TV
I have a 55 inch curved TV from 2015. The TV goes black every 5 minutes but I still have sound. If I turn the TV off then back on again it's fine for about five minutes then black again.
Tried pretty much everything on the menu button, also discontinued my Xbox. Pulled the plug for 30 minutes but this doesn't work either.
8 REPLIES 8
xSteveuk
Black Belt
TV
Hi,
This page maybe helpful to you
Samsung TV has no picture or a black screen
https://www.samsung.com/us/support/troubleshooting/TSG01109749/
Smc14
TV
Cheers. I have tried this page but no luck with it. At the moment nothing connected to the TV.
Galaxyyouser21
Helping Hand
TV
Is the TV mounted on a wall plate or adjustable mount ?
Smc14
TV
No neither. Just free standing on a TV cabinet.
Galaxyyouser21
Helping Hand
TV
Have you tried connecting to the Internet with ethernet cable and opening YouTube on your app screen ? And make sure that every single cable is disconnected from the TV sockets apart from the power and ethernet ones.
Smc14
TV
Nothing connected to the TV just the areial and power lead, did have an Xbox connected but took that off. The internet is on WiFi at the moment, but all seems well with that part of the TV. I'm a bit puzzled, nothing seems to be working.
Galaxyyouser21
Helping Hand
TV
Ok, unplug the aerial cable. Unplug the TV from the wall for 2 minutes. Plug the TV back in and turn it on. Then press the source button and change it to a different hdmi port
Jp46
TV
Looks like a transistor or something supplying the picture in the motherboard is on its way out
