Tv samsung with lines after a few minutes
(Topic created on: 15-04-2024 11:40 AM)
Tonytt
Hi all,
My TV starts displaying lines after turning it on for a few minutes (2-5 minutes). I tried to power down the TV, waited for a few minutes, then powered it up. The screen looked alright for a few minutes then the issue started again.
Any idea why it happened? Thanks!
1 REPLY 1
JAMES4578
Samsung Members Star ★★
Hi @Tonytt   Whilst  you can   disconnect external  devices and reconnect to see if that makes a difference,with the Picture Test failure indicates  it could a hardware problem (issue with panel) and would need an inspection. Not sure if you have had this model for a while or not.  Contact details on Samsung Support. https://www.samsung.com/uk/support/contact/
