TV's unable to boot after firmware upgrade
(Topic created on: 10-08-2018 08:57 PM)
Bimalska
kkk
10 REPLIES 10
ChrisM
SuperStar
Hi @Bimalska.
Did you manage to get this sorted?
Bimalska
@ ChrisM
Unfortunately, not
Madasahat
Voyager
Is there a way to reinstall the firmware via a USB stick if the tv a least boots up?
Bimalska
No. After logo its blank
Madasahat
Voyager
That is a good thing perhaps (maybe not good at this moment) If you contact support they may be able to run you through a way to instal the firmware if you can get the update files on a USB drive. Then try to update again and hope it takes. That is all I can suggest as I have not had this problem. Hope you get it sorted
Bimalska
@Madasahat
That won't help. Anyway, thanks for your suggestion.
Madasahat
Voyager
@Bimalska wrote:
@Madasahat
If that won't help have you been told what will fix it? Or what has been done to rectify your problem so others can use what you did if it happens to them.
The reason I suggested that was sometimes at least if it powers on hope may not fully be lost.
Please keep us informed on the situation and what Samsung did
Bimalska
Still wishing for the resolution.
Not yet resolve.
Not happy to see just Samsung logo.
Samsung should be updating on this issue
CarlH
Have you contacted out Support Team regarding this, @Bimalska
