TV Remote Controls
(Topic created on: 14-04-2022 04:07 PM)
cl06
Just bought Samsung UE43AU7100, it has two remotes, i set the tv up with the smart remote and it works fine but how do i change to using the standard remote because nothing happens when i press any of the buttons on the standard remote.
3 REPLIES 3
TRY2HELP
Helping Hand
Change the battery see that work
Blessed4life
Black Belt
Hi, double check there's batteries in the remote & are correctly placed, because I also have a Samsung 8 series 55inch smart TV that came with a smart remote & a standard remote & they both work simultaneously.20220414_161622_1516_1649949388.jpg
cl06
Hi thanks got it sorted, it had brand new batteries in and would not work, replaced with used batteries and worked.
