Go to solution Solved
TV: QE75Q70TATXXC
(Topic created on: 31-12-2020 09:57 AM)
Sasch81hs
Hi,
I bought this TV last week and it seems like that there is a folie on the screen. I am not sure if this should be removed or should it stay on the screen?
BR
//Sascha
PaulyWauly36
Pathfinder
if there are no loose bits you can get hold of then it stays
4 REPLIES 4
PaulyWauly36
Pathfinder
if it is attached to the 2 platic strips at the edge of the screen,it comes off, usually loose at thr botton,pull it diagonaly away from screen
Sasch81hs
I am still unsure if it should come off. I see it only attached to the screen not to any plastic stripes. could it be that the TV have something like a folie which needs to stay?
PaulyWauly36
Pathfinder
if there ar
PaulyWauly36
Pathfinder
