TV protector on Samsung QE50Q60T?
(Topic created on: 28-09-2020 06:31 PM)
JimmyD7
TV
Bit disappointed with sharpness on my new TV but now wondering if it actually has a screen protector on it that needs to be removed. Thought it was strange that didn't come with one as has tape all around the outside of the bezel but seemingly no screen protector. However, there does appear to be some sort of covering but can't easily peel off from corner and don't want to damage the TV if it's some sort of filter that's meant to be there.
Any advice would be much appreciated.
2 REPLIES 2
Raxamillion
TV
my Q90R had a screen protector, at t least I think it did, removed it and the picture is perfect.
JimmyD7
TV
Thanks for your response. Was it tough to remove? I can't get my nail in to remove the edge and paranoid about removing something I shouldn't or scratching the TV, can you recall it being tricky?
