TV Plus will not load
(Topic created on: 28-01-2019 11:51 AM)
LollyWG
 Our television was purchased early 2018 - I don't remember the model number at the moment as I am at work but it is a UE50MU...........   About 2 weeks ago the TV Plus app would not load.  Every time I tried to select a film it switched to one of the other 4000/4001/4002 or 4003 channels.  I contacted Samsung and they looked at the television remotely.  Reset the Smart Hub twice, reset the television three times and still had the same problem.  I was told by Samsung that it is an app issue and to contact TV Plus.  TV Plus say its a Samsung problem.  Then last night another problem appeared.  We couldn't get any terrestrial channels.  I have the Live TV Terrestrail app where the television scanned for all the digital channels, but it wouldn't connect and said there is no connection.   I then tried TV Plus and was surprised to see that the television channels were on there.  Initially selected BBC one but it then went blank.  Then after trying again selected BBC one again and managed to watch the programme.  I am now concerned that our television has more problems just than an App not loading.
Has anyone else experienced problems with their apps or television?
Many thanks for your comments,
Lorraine
30 REPLIES 30
GrannyTeri-1
I just bought a  Samsung M4500 Series last week. Two days after that all the  TVPLus channels when blank. I can't seem to get them back. I have even reset the Tv. Still nothing. I really like the Classic Tv channel that was on there. Gone now.  Not happy with my Samsung TV.
Terrie
stangweb77
I just bought a new Samsung TV a few weeks ago. And my Samsung TV app won't load either
Tim052198
My tv plus app say it is no longer available and I have purchased movies on there
Joe_T
Samsung's TV Plus partnered with Fandango for this service no longer available. However, you can find all your purchased content on the Fandango app using the same credentials. I hope this helped. If additional help is required, please contact FandangoNow customer support.
Buddhistpri3st
Turned on tv to play Samsung plus TV and it said "content unavailable, please check your server." Or something along those lines. I eneded up going to my settings, went to "TV device manager" and it gives you the option to "clean" certain things such as cache, close running apps and free up storage. I did this and it started working again!
Dannyboy2111
I have a Similar Problem only with mine when I try to Open it I get a Black Screen that just sits there and does nothing
Spawn7900
I had the same issue just now, I unplugged the TV for about 5 minutes. Once I plugged it back in, it re signed in to samsung account and worked.
Teresa57
How do you get to tv device manager?
My tv plus keeps saying error
Dannyboy2111
Gonna give your Suggestion a Try unplugging the TV and see if it works Spawn7900
