Tv pin on tv ks8000
(Topic created on: 13-10-2019 09:46 AM)
Galafootball
Hi forum
iv'e just purchased a ks8000 smartvtv  off another user, i was trying to do some alterations on tv, but it keeps asking for pin,it is also set with old users samsung acvount which i'd like to remove.. I've asked previous owner, but his pin fails, I've tried default pin & still no good, also tried the
mute/2/4/power setting but no good
looking for assistances please
thankyou
1 REPLY 1
RpBP
Mastermind
Hi @Galafootball are you try to reset to default, I do not sure if you will need code for that, but try it.
Also you can use the tecnical service or remote control request for some operations on your TV, ask about it, and try to explain what happened there with the TV.
Good luck and wait the intervention of a Community Moder to help you with tasks :four-leaf-clover:
You adquired a real beauty TV for you :thumbs-up-sign-emoji-modifier-fitzpatrick-type:
